Introdução
A rugged outdoor lifestyle may sometimes cause the cover, of your Solio Rocsta, to get dirty and/or damaged. In this guide, we will show you how to remove the top cover of the Solio Rocsta and replace it.
  1. Locate, and unscrew, the three 5.72 mm screws that hold down the top cover using the T6 Torx screwdriver. Locate, and unscrew, the three 5.72 mm screws that hold down the top cover using the T6 Torx screwdriver.
    • Locate, and unscrew, the three 5.72 mm screws that hold down the top cover using the T6 Torx screwdriver.
  2. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  3. Remove top cover. Caution: the solar cell is attached to the top cover and connected to the circuit board by a short wire .
    • Remove top cover.
    • Caution: the solar cell is attached to the top cover and connected to the circuit board by a short wire .
  4. Using the spudger, pry the solar panel off the cover.
    • Using the spudger, pry the solar panel off the cover.
Conclusão
Denis Laesker
107 reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S13-G13, Cagle Fall 2017 Membro de USF Tampa, Team S13-G13, Cagle Fall 2017
USFT-CAGLE-F17S13G13
4 Membros
6 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 23
