Ir para o conteúdo principal
Solio Rocsta Charging Cable Replacement
O que você precisa
  1. Solio Rocsta Charging Cable Replacement, Charging Cable: passo 1, imagem 1 %32 Solio Rocsta Charging Cable Replacement, Charging Cable: passo 1, imagem 2 %32
    • Locate, and unscrew, the three 5.72 mm screws that hold down the top cover using the T6 Torx screwdriver.
  2. Solio Rocsta Charging Cable Replacement: passo 2, imagem 1 %32 Solio Rocsta Charging Cable Replacement: passo 2, imagem 2 %32
    • Remove top cover.
    • Caution: the solar cell is attached to the top cover and connected to the circuit board by a short wire.
  3. Solio Rocsta Charging Cable Replacement: passo 3, imagem 1 %32
    • Using the spudger, pry the battery off the back cover.
  4. Solio Rocsta Charging Cable Replacement: passo 4, imagem 1 %32
    • Unscrew the 5.66 mm screws attaching the circuit board to the case.
  5. Solio Rocsta Charging Cable Replacement: passo 5, imagem 1 %32
    • With the circuit board flipped, locate the battery connector.
    • Hold the component attached to the circuit board the battery is connected to and wiggle the cable out.
  6. Solio Rocsta Charging Cable Replacement: passo 6, imagem 1 %32
    • With a Soldering Iron, desolder the four cables that connect the charging cable to the circuit board.
    • The power cable is a series of four cables. Make note of each cable placement for easy resoldering.
    • For more information on how to solder and desolder connections, please visit this guide.
Conclusão
David Vazquez
Membro desde: 10/10/17
577 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S13-G13, Cagle Fall 2017 Membro de USF Tampa, Team S13-G13, Cagle Fall 2017
USFT-CAGLE-F17S13G13
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 180
