Ir para o conteúdo principal
Sol Republic Deck Bluetooth Button Replacement
O que você precisa
  1. Sol Republic Deck Bluetooth Button Replacement, Bluetooth Button: passo 1, imagem 1 %32
    • With plastic spudger wedge in between the top and bottom casings to force sepearation . Exposing the inside components of the Republic Deck.
  2. Sol Republic Deck Bluetooth Button Replacement: passo 2, imagem 1 %32
    • Use the screwdriver to unscrew two 3.6mm Phillips #0 screws securing the plastic plate.
  3. Sol Republic Deck Bluetooth Button Replacement: passo 3, imagem 1 %32
    • Remove the ribbon cable from the circuit board.
  4. Sol Republic Deck Bluetooth Button Replacement: passo 4, imagem 1 %32
    • Plug in de-soldering kit and wait 3 minutes for the solder to heat up.
    • Use the tip of your soldering iron to heat the old solder unit and apply until it melts.
    • Remove speaker wires connecting the speaker to the circuit board.
  5. Sol Republic Deck Bluetooth Button Replacement: passo 5, imagem 1 %32
    • Unscrew five 3.6 mm Phillips #0 screws securing the circuit board.
  6. Sol Republic Deck Bluetooth Button Replacement: passo 6, imagem 1 %32
    • Unscrew fifteen 6.2mm Phillips #0 screws and lift the black plastic plate from the case.
  7. Sol Republic Deck Bluetooth Button Replacement: passo 7, imagem 1 %32 Sol Republic Deck Bluetooth Button Replacement: passo 7, imagem 2 %32
    • Remove the three 3.6mm Phillips #0 screws.
    • Remove the circuit board containing the BlueTooth button.
Conclusão
Uma outra pessoa concluiu este guia.
Jonathan Holtman
Membro desde: 03/20/17
368 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S3-G1, Baechle Spring 2017 Membro de IUPUI, Team S3-G1, Baechle Spring 2017
IUPUI-BAECHLE-S17S3G1
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 6
Últimos 30 dias: 9
Duração total: 552
