Ir para o conteúdo principal
Softball Glove String Replacement
O que você precisa
  1. Softball Glove String Replacement, Softball Glove String: passo 1, imagem 1 %32 Softball Glove String Replacement, Softball Glove String: passo 1, imagem 2 %32 Softball Glove String Replacement, Softball Glove String: passo 1, imagem 3 %32
    • Tie a knot at one end of the string.
  2. Softball Glove String Replacement: passo 2, imagem 1 %32 Softball Glove String Replacement: passo 2, imagem 2 %32
    • Put the string through the loop of the leather needle.
  3. Softball Glove String Replacement: passo 3, imagem 1 %32 Softball Glove String Replacement: passo 3, imagem 2 %32
    • Push the needle through the first hole on the backside of the pinky finger.
  4. Softball Glove String Replacement: passo 4, imagem 1 %32 Softball Glove String Replacement: passo 4, imagem 2 %32 Softball Glove String Replacement: passo 4, imagem 3 %32
    • Pull the string out of the needle and back the needle out of the hole.
  5. Softball Glove String Replacement: passo 5, imagem 1 %32 Softball Glove String Replacement: passo 5, imagem 2 %32
    • Pull the string all the way through and reinsert the string into the needle.
  6. Softball Glove String Replacement: passo 6, imagem 1 %32 Softball Glove String Replacement: passo 6, imagem 2 %32
    • Push the needle through the bottom hole on the ring finger.
    • Pull the string out of the needle and all the way through the hole. Back the needle out of the hole.
  7. Softball Glove String Replacement: passo 7, imagem 1 %32 Softball Glove String Replacement: passo 7, imagem 2 %32 Softball Glove String Replacement: passo 7, imagem 3 %32
    • Insert the string back into the needle and push it through the bottom hole on the pinky.
    • Pull the string all the way through and remove it from the needle.
  8. Softball Glove String Replacement: passo 8, imagem 1 %32 Softball Glove String Replacement: passo 8, imagem 2 %32 Softball Glove String Replacement: passo 8, imagem 3 %32
    • Pull the string under the loop, making an X.
  9. Softball Glove String Replacement: passo 9, imagem 1 %32 Softball Glove String Replacement: passo 9, imagem 2 %32 Softball Glove String Replacement: passo 9, imagem 3 %32
    • Put the string through the needle and push the needle though the top hole on the ring finger.
  10. Softball Glove String Replacement: passo 10, imagem 1 %32 Softball Glove String Replacement: passo 10, imagem 2 %32 Softball Glove String Replacement: passo 10, imagem 3 %32
    • Going around the back of the ring finger, insert the string through the top hole on the left side of the ring finger.
    • Pull the string all the way through.
  11. Softball Glove String Replacement: passo 11, imagem 1 %32 Softball Glove String Replacement: passo 11, imagem 2 %32 Softball Glove String Replacement: passo 11, imagem 3 %32
    • Insert the string through the bottom hole on the middle finger.
  12. Softball Glove String Replacement: passo 12, imagem 1 %32 Softball Glove String Replacement: passo 12, imagem 2 %32
    • Cross over the backside and insert the string into the bottom hole on the left side of the ring finger.
  13. Softball Glove String Replacement: passo 13, imagem 1 %32 Softball Glove String Replacement: passo 13, imagem 2 %32 Softball Glove String Replacement: passo 13, imagem 3 %32
    • Pull the string under the loop to make an X.
  14. Softball Glove String Replacement: passo 14, imagem 1 %32 Softball Glove String Replacement: passo 14, imagem 2 %32 Softball Glove String Replacement: passo 14, imagem 3 %32
    • Push the string through the top hole on the right side of the middle finger.
  15. Softball Glove String Replacement: passo 15, imagem 1 %32 Softball Glove String Replacement: passo 15, imagem 2 %32 Softball Glove String Replacement: passo 15, imagem 3 %32
    • Going around the back of the middle finger, insert the string into top hole on the right side of the middle finger.
  16. Softball Glove String Replacement: passo 16, imagem 1 %32 Softball Glove String Replacement: passo 16, imagem 2 %32 Softball Glove String Replacement: passo 16, imagem 3 %32
    • Insert the string into the bottom right hole on the pointer finger.
  17. Softball Glove String Replacement: passo 17, imagem 1 %32 Softball Glove String Replacement: passo 17, imagem 2 %32 Softball Glove String Replacement: passo 17, imagem 3 %32
    • On the backside, push the string through the bottom left hole on the middle finger and pull the string all the way through.
  18. Softball Glove String Replacement: passo 18, imagem 1 %32 Softball Glove String Replacement: passo 18, imagem 2 %32 Softball Glove String Replacement: passo 18, imagem 3 %32
  19. Softball Glove String Replacement: passo 19, imagem 1 %32 Softball Glove String Replacement: passo 19, imagem 2 %32 Softball Glove String Replacement: passo 19, imagem 3 %32
    • Insert the string into the top right hole on the pointer finger and pull the string all the way through.
  20. Softball Glove String Replacement: passo 20, imagem 1 %32 Softball Glove String Replacement: passo 20, imagem 2 %32 Softball Glove String Replacement: passo 20, imagem 3 %32
    • Tie the end of the string close to the glove.
    • Cut off the excess string.
Conclusão
To remove a string from a softball glove, repeat these steps in reverse order.
Uma outra pessoa concluiu este guia.
Christina Hart
Membro desde: 03/23/21
331 Reputação
Autoria de 1 guia
Equipe
Um comentário
Thank you so much for sharing this guide on softball glove string replacement! Your step-by-step instructions made it easy for me to replace the strings on my old glove and bring it back to life. Your expertise and generosity are truly appreciated!
Juliet Cyrus - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 25
Duração total: 939
