Ir para o conteúdo principal
SodaStream Fountain Jet A200 Spring Replacement
  1. SodaStream Fountain Jet A200 Spring Replacement, removing back cover: passo 1, imagem 1 %32 SodaStream Fountain Jet A200 Spring Replacement, removing back cover: passo 1, imagem 2 %32
    • Press in the two gray buttons found on either side, at the top of the machine.
    • Pull back on the cover until it releases from the device and pull the back off.
  2. SodaStream Fountain Jet A200 Spring Replacement, Carbonation button: passo 2, imagem 1 %32 SodaStream Fountain Jet A200 Spring Replacement, Carbonation button: passo 2, imagem 2 %32
    • Place your hand under the carbonation button and gently pull up and away from you, towards the back of the machine.
  3. SodaStream Fountain Jet A200 Spring Replacement, spring removal: passo 3, imagem 1 %32 SodaStream Fountain Jet A200 Spring Replacement, spring removal: passo 3, imagem 2 %32
    • Remove the spring located under the carbonation button.
    • Replace with the new spring, by lining it up and pushing it down.
Conclusão
5 outras pessoas executaram este guia.
2Comentários do guia
Does anyone know where I can get a carbonation button?
draganr@wi.rr.com
draganr - Responder Compartilhar
Do we know the spring parameters?
Outside Diameter
Inside Diameter
Overall Length
Wire Diameter
Total # of Coils
Active # of Coils
Solid Height
Space between the Coils
John Friedman - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 18
Últimos 30 dias: 56
Ao todo: 11,278
