Ir para o conteúdo principal
Snow Blower Shear Bolt Replacement
O que você precisa
  1. Snow Blower Shear Bolt Replacement, Locate new shear bolt: passo 1, imagem 1 %32
    • The new shear bolt is stored on the top of the auger discharge
  2. Snow Blower Shear Bolt Replacement, Remove the old shear bolt: passo 2, imagem 1 %32 Snow Blower Shear Bolt Replacement, Remove the old shear bolt: passo 2, imagem 2 %32 Snow Blower Shear Bolt Replacement, Remove the old shear bolt: passo 2, imagem 3 %32
    • The shear bolt attaches the auger to the shaft
    • The shear bolt is designed to break preventing damage to the auger and shaft if an hard object is pulled in
    • Locate the side with the missing shear bolt
    • The left side is missing
    • This auger will spin freely on this side
    • Rotate the auger to find where the bolt is on the shaft
  3. Snow Blower Shear Bolt Replacement: passo 3, imagem 1 %32 Snow Blower Shear Bolt Replacement: passo 3, imagem 2 %32
    • Use the new shear bolt to push the old broken bolt out of the shaft
    • It should fall out and look like this
  4. Snow Blower Shear Bolt Replacement: passo 4, imagem 1 %32 Snow Blower Shear Bolt Replacement: passo 4, imagem 2 %32
    • With the new bolt in place from pushing the old bolt out add a nut
    • Hand tighten
  5. Snow Blower Shear Bolt Replacement: passo 5, imagem 1 %32 Snow Blower Shear Bolt Replacement: passo 5, imagem 2 %32
    • Using two 7/16" wrenches tighten the nut on the bolt
    • Do not over tighten
    • Congratulations, both shear bolts have been replaced
Conclusão
Jacob Rattray
Membro desde: 05/11/18
263 Reputação
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 11
Ao todo: 1,665
