Ir para o conteúdo principal
Snapfon ez One SIM Card Replacement
O que você precisa
  1. Snapfon ez One SIM Card Replacement, Remove the battery cover: passo 1, imagem 1 %32
    • Turn off the phone to prevent data loss.
    • Press and slide the battery out to remove it.
    • Picture rights belong to Snapfon®. Picture is used for educational purposes only. No copyright infringement intended.
  2. Snapfon ez One SIM Card Replacement, Remove the battery: passo 2, imagem 1 %32
    • Pry the battery out with your thumb or the iFixit opening tool.
    • Make sure to properly dispose of the old battery at a recycling center.
  3. Snapfon ez One SIM Card Replacement, SIM Card: passo 3, imagem 1 %32
    • Use the tweezers,if needed, to grasp the SIM card for removal. Apply a slight pulling tension and remove it from under the tabs as shown.
Conclusão
To reinsert the SIM card or a new SIM card, position the card in the same orientation seen in the figure with the brass connections facing the phone while using thumb to apply a slight force until the card rest inside of the recessed holder. Make sure the brass contacts of the card and phone connect. Then follow the steps in reverse order to reassemble phone.
John Bender
Membro desde: 03/26/14
818 Reputação
Autoria de 8 guias
Equipe
Clemson, Team 6-5, Benson Spring 2014 Membro de Clemson, Team 6-5, Benson Spring 2014
CLEM-BENSON-S14S6G5
Membros da 3
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 1,143
