Introdução
The charging port is the component of the phone that allows the charger to be connected to the phone in order to charge the internal rechargeable battery.
Peças
Não são necessárias peças.
Make sure the phone is turned off by pressing the power off button ensuring no data is lost.
Remove the back battery cover by sliding it downward and pushing simultaneously.
Remove the rubber inserts from the screw holes using the black metal tweezers. This is done by insering the tip of the metal tweezer down around the plastic insert.
Use tweezers to remove the charging port located inside the back cover of the phone.
A spudger may be needed to apply pressure with the use of the tweezers for easier removal.
Insert new charging port, and to reassemble your device, follow these instructions in reverse order.
