Ir para o conteúdo principal
Smartab STJR700 Screen/Digitizer Replacement
O que você precisa
  1. Smartab STJR700 Screen/Digitizer Replacement, Screen/Digitizer: passo 1, imagem 1 %32 Smartab STJR700 Screen/Digitizer Replacement, Screen/Digitizer: passo 1, imagem 2 %32
    • There are four screws with each one in each corner. Use the screwdriver to unscrew the back or bottom of the device.
  2. Smartab STJR700 Screen/Digitizer Replacement: passo 2, imagem 1 %32
    • Remove the bottom or back of the device by detaching the black bottom after removing the screws.
    • the front panel should now be exposing the digitizer along with the other electronic components of the device.
  3. Smartab STJR700 Screen/Digitizer Replacement: passo 3, imagem 1 %32 Smartab STJR700 Screen/Digitizer Replacement: passo 3, imagem 2 %32
    • Next, remove the circuit board from the front panel and screen. This should leave the digitizer and circuit board intact.
    • Afterward, remove the existing damaged glass part of the device from the front panel as shown in the last picture.
    • Finally add a new STJR700 screen and reverse the previous steps to reattach the device.
Conclusão
Uma outra pessoa concluiu este guia.
Tianna Edwards
Membro desde: 03/22/17
128 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 19
Ao todo: 1,283
