Ir para o conteúdo principal
Smartab STJR700 Charging Port Replacement
O que você precisa
  1. Smartab STJR700 Charging Port Replacement, Charging Port: passo 1, imagem 1 %32
    • Power off the device by holding down the lock button. Remove the case from the tablet and place it face down.
  2. Smartab STJR700 Charging Port Replacement: passo 2, imagem 1 %32
    • Unscrew all four corner screws using the PH000 screwdriver head found in the iFixit kit.
  3. Smartab STJR700 Charging Port Replacement: passo 3, imagem 1 %32
    • CAUTION: Avoid touching the display.
    • Pry open the tablet using a metal spudger. Set aside the back panel.
  4. Smartab STJR700 Charging Port Replacement: passo 4, imagem 1 %32
    • Locate the charging port.
  5. Smartab STJR700 Charging Port Replacement: passo 5, imagem 1 %32 Smartab STJR700 Charging Port Replacement: passo 5, imagem 2 %32
    • Unscrew all the labeled screws using the PH000 screwdriver head.
  6. Smartab STJR700 Charging Port Replacement: passo 6, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Remove all pieces of tape using the tweezers provided in the iFixit kit.
    • Remove the two ribbon cables affixed to the camera.
  7. Smartab STJR700 Charging Port Replacement: passo 7, imagem 1 %32
    • Remove the motherboard component from the screen and display.
    • Because the charging port is soldered onto the motherboard, the motherboard must be replaced by one specifically made for the Smartab STJR700.
Conclusão
Thi Le
Membro desde: 03/08/17
101 Reputação
Autoria de 1 guia
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 1,013
