Ir para o conteúdo principal
SmartDevil Snow Mountain USB Humidifier Filter Replacement
O que você precisa
  1. SmartDevil Snow Mountain USB Humidifier Filter Replacement, Cotton Filter: passo 1, imagem 1 %32 SmartDevil Snow Mountain USB Humidifier Filter Replacement, Cotton Filter: passo 1, imagem 2 %32
    • Unscrew the tank cap counterclockwise to open the humidifier.
    • Pour out all the water to avoid the smell.
  2. SmartDevil Snow Mountain USB Humidifier Filter Replacement: passo 2, imagem 1 %32 SmartDevil Snow Mountain USB Humidifier Filter Replacement: passo 2, imagem 2 %32
    • Slightly twist the filter compartment counterclockwise until it clicks.
    • Pull the filter compartment out.
  3. SmartDevil Snow Mountain USB Humidifier Filter Replacement: passo 3, imagem 1 %32 SmartDevil Snow Mountain USB Humidifier Filter Replacement: passo 3, imagem 2 %32
    • Take the cotton filter and the spring metal out of the compartment.
    • Be sure not to lose the metal spring in the compartment.
  4. SmartDevil Snow Mountain USB Humidifier Filter Replacement: passo 4, imagem 1 %32 SmartDevil Snow Mountain USB Humidifier Filter Replacement: passo 4, imagem 2 %32
    • Take a new cotton filter. Cut the new filter equal to the length of the compartment.
    • If your cotton filter's length is equal to the length of the compartment, skip this step.
  5. SmartDevil Snow Mountain USB Humidifier Filter Replacement: passo 5, imagem 1 %32
    • Soak the new cotton filter in mineral water or tap water for 3 to 5 minutes.
    • Avoid using pure water or distilled water to prevent clogging on the mist outlet.
  6. SmartDevil Snow Mountain USB Humidifier Filter Replacement: passo 6, imagem 1 %32 SmartDevil Snow Mountain USB Humidifier Filter Replacement: passo 6, imagem 2 %32
    • Place the metal spring at the bottom of the compartment.
    • Insert the new cotton filter into the compartment, put the new filter on top of the metal spring.
  7. SmartDevil Snow Mountain USB Humidifier Filter Replacement: passo 7, imagem 1 %32
    • Plug the compartment to the tank cap. Slightly twist the compartment clockwise to lock it.
  8. SmartDevil Snow Mountain USB Humidifier Filter Replacement: passo 8, imagem 1 %32
    • Use a cotton swab to clean dust and mold on the mist outlet.
    • Cleaning the mist outlet occasionally will improve the mist quality.
  9. SmartDevil Snow Mountain USB Humidifier Filter Replacement: passo 9, imagem 1 %32
    • Fill the tank with water and close the tank cap.
Conclusão
5 outras pessoas executaram este guia.
Thu Pham
Membro desde: 05/13/21
304 Reputação
Autoria de 1 guia
8 comentários
do all smart devil humidifiers have springs i did not see the in mine
Kim Pederson - Responder
Where do I get a replacement cotton filter?
Margaret White - Responder
Boao 40 Pieces Humidifier Sticks Cotton Filter Refill Travel Humidifier Sticks Car Humidifier Replacement Parts for Mini Portable Personal USB Powered Humidifiers in Office Bedroom (4 Inch) https://a.co/d/0MpspKK
Jmat -
I have 3 of these, 1 pumps out the perfect amount of humidity and last about 20 hours but 2 of them pump out waaay too much! They empty in 8 hours. Is there a way to slow them down? The slower one is absolutely perfect I would like them all the same. Help please
Kelly Locke - Responder
Where do I get the spring, mine didnt have one, can I order one
joann brown - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 18
Últimos 30 dias: 137
Duração total: 12,105
