Ir para o conteúdo principal
Smart Tweezers and LCR-Reader LCR-meter Screen Replacement
O que você precisa
  1. Smart Tweezers and LCR-Reader LCR-meter Screen Replacement, Opening the device: passo 1, imagem 1 %32 Smart Tweezers and LCR-Reader LCR-meter Screen Replacement, Opening the device: passo 1, imagem 2 %32
    • Start by removing the 4 screws in the back of the device using a size 00 Philips screw driver.
  2. Smart Tweezers and LCR-Reader LCR-meter Screen Replacement, Replacing the screen: passo 2, imagem 1 %32 Smart Tweezers and LCR-Reader LCR-meter Screen Replacement, Replacing the screen: passo 2, imagem 2 %32
    • Gently open the zif connector that holds the screen.
    • Insert the replacement screen, and close the zif
  3. Smart Tweezers and LCR-Reader LCR-meter Screen Replacement, Closing the device: passo 3, imagem 1 %32
    • When closing the housing, make sure the screen fits into the rectangle on the top.
    • If the screen is not in this rectangle, it may become damaged when the screws are tightened
    • Hold the screen in place from below; line up the button's edge of the top housing to line up with the bottom housing. Slide your finger out as you bring the top and bottom housings to meet.
    • Replace the 4 Philips screws in the back.
Linha de Chegada
Uma outra pessoa concluiu este guia.
brittany
Membro desde: 07/16/12
234 Reputação
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Ao todo: 554
