Ir para o conteúdo principal
Smart Parts Ion Eyes Replacement
O que você precisa
  1. Smart Parts Ion Eyes Replacement, Hopper and the Air Tank: passo 1, imagem 1 %32 Smart Parts Ion Eyes Replacement, Hopper and the Air Tank: passo 1, imagem 2 %32 Smart Parts Ion Eyes Replacement, Hopper and the Air Tank: passo 1, imagem 3 %32
    • Remove the air tank by rotating it counterclockwise.
    • Do not pull the trigger or jostle the gun, there will still be pressurized air inside the gun that could be expelled and cause bodily harm if injected into eyes and/or skin.
    • The pressure gauge will indicate the leftover air in the gun.
  2. Smart Parts Ion Eyes Replacement: passo 2, imagem 1 %32 Smart Parts Ion Eyes Replacement: passo 2, imagem 2 %32
    • Remove the hopper by pulling it out of the feed tube, located on the top of the body. The hopper should easily come off when pulled straight up.
  3. Smart Parts Ion Eyes Replacement, Smart Parts Ion De-Gassing: passo 3, imagem 1 %32
    • Turn the gun on by pressing the power button until the red light blinks.
    • Turn vision mode off by pressing the power button again.
    • Red light should be flashing in a double blink sequence.
  4. Smart Parts Ion Eyes Replacement: passo 4, imagem 1 %32
    • Pull the trigger to release the air in the gun.
    • Pressurized air can be forceful, causing particles to be ejected from the gun into your eyes and/or skin. When air bubbles enter the bloodstream, they can block blood vessels, causing embolisms. To avoid this, make sure to point the gun in a safe direction when pulling the trigger because air will be released from the gun.
  5. Smart Parts Ion Eyes Replacement, Grip: passo 5, imagem 1 %32
    • Remove the four 8mm screws on each side of the gun's grip using a Phillips #2 screwdriver.
  6. Smart Parts Ion Eyes Replacement: passo 6, imagem 1 %32
    • Remove the grip by sliding it towards the front of the gun.
  7. Smart Parts Ion Eyes Replacement, Battery: passo 7, imagem 1 %32 Smart Parts Ion Eyes Replacement, Battery: passo 7, imagem 2 %32
    • Remove the 9V battery by unsnapping it.
  8. Smart Parts Ion Eyes Replacement, Separate Body From Grip Frame: passo 8, imagem 1 %32 Smart Parts Ion Eyes Replacement, Separate Body From Grip Frame: passo 8, imagem 2 %32 Smart Parts Ion Eyes Replacement, Separate Body From Grip Frame: passo 8, imagem 3 %32
    • Remove the front and rear 1" screws on the gun's grip frame using a 3/32" Allen Wrench.
  9. Smart Parts Ion Eyes Replacement: passo 9, imagem 1 %32 Smart Parts Ion Eyes Replacement: passo 9, imagem 2 %32
    • Remove the 12 mm screw on the top of the grip frame using a 3/32" Allen wrench.
  10. Smart Parts Ion Eyes Replacement: passo 10, imagem 1 %32
    • Separate the gun's body from the frame by gently pulling them in opposite directions.
  11. Smart Parts Ion Eyes Replacement: passo 11, imagem 1 %32
    • Remove the 1-1/4" screw that's attached to the blue tube above the front grip using a 3/32" Allen Wrench.
  12. Smart Parts Ion Eyes Replacement, Eyes: passo 12, imagem 1 %32 Smart Parts Ion Eyes Replacement, Eyes: passo 12, imagem 2 %32
    • Remove the gun's green vision eye board by gently pulling it out using your index finger and thumb.
Conclusão
Shane Villalpando
Membro desde: 02/02/15
1.031 Reputação
Autoria de 10 guias
Equipe
Cal Poly, Team 8-42, Amido Winter 2015 Membro de Cal Poly, Team 8-42, Amido Winter 2015
CPSU-AMIDO-W15S8G42
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 6
Duração total: 1,457
