Ir para o conteúdo principal
Small Engine Recoil Starter Replacement
O que você precisa
  1. Small Engine Recoil Starter Replacement, Recoil Starter: passo 1, imagem 1 %32
    • To begin the repair remove the protective casing. (This removal may vary with different lawnmowers.)
  2. Small Engine Recoil Starter Replacement: passo 2, imagem 1 %32
    • Locate the recoil housing cap.
  3. Small Engine Recoil Starter Replacement: passo 3, imagem 1 %32
    • Carefully remove the housing cap. (Removal may vary)
  4. Small Engine Recoil Starter Replacement: passo 4, imagem 1 %32
    • After removing the recoil, unscrew the cap that holds the pulley to the recoil starter housing.
  5. Small Engine Recoil Starter Replacement: passo 5, imagem 1 %32
    • Untie the knot in the rope and slide it out of the housing.
  6. Small Engine Recoil Starter Replacement: passo 6, imagem 1 %32
    • With this particular model there is a middle lock piece. Use a socket wrench to unscrew and release the coil.
  7. Small Engine Recoil Starter Replacement: passo 7, imagem 1 %32
    • Once unscrewed, remove the metal piece which releases the tension on the coil.
  8. Small Engine Recoil Starter Replacement: passo 8, imagem 1 %32
    • At this point add the new coil to the housing base. Snap the coil into position where the old on was.
Conclusão
5 outras pessoas executaram este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 13
Ao todo: 3,208
