Ir para o conteúdo principal
Sliding Folding Door Hinge Replacement
O que você precisa
  1. Sliding Folding Door Hinge Replacement, Hinge: passo 1, imagem 1 %32
    • Using the Phillips #2 screwdriver, remove any remaining old screws and hinges that you want to replace.
    • Counterclockwise will remove the screws.
  2. Sliding Folding Door Hinge Replacement: passo 2, imagem 1 %32
    • Screws come loose when the holes become too large for the screws. If necessary, drill new holes into the door.
    • In this case, the top two holes were no longer usable, so we created more underneath the bottom holes.
  3. Sliding Folding Door Hinge Replacement: passo 3, imagem 1 %32 Sliding Folding Door Hinge Replacement: passo 3, imagem 2 %32
    • One by one, use the screwdriver to place the new screws.
    • The screws shouldn't be too tight. Be sure that the hinge is loose enough to rotate while placing the other screws.
    • Tighten all screws best you can with the hand held screwdriver.
  4. Sliding Folding Door Hinge Replacement: passo 4, imagem 1 %32
    • The new hinge and screws should be in place now. If you would like, you can patch up the old holes and paint over them.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 10
Últimos 30 dias: 20
Duração total: 662
