Ir para o conteúdo principal
Skytex SP728 Speakers Replacement
O que você precisa
  1. Skytex SP728 Speakers Replacement, Case: passo 1, imagem 1 %32
    • Make sure the device is powered off
    • Rotate the device so the ports and screws face you
  2. Skytex SP728 Speakers Replacement: passo 2, imagem 1 %32
    • Using a small phillips screwdriver, unscrew both end screws
  3. Skytex SP728 Speakers Replacement: passo 3, imagem 1 %32
    • Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
  4. Skytex SP728 Speakers Replacement: passo 4, imagem 1 %32
    • Once the case has been loosened, pry the backing off gently with your hands.
    • Make sure to remove the case gently as extra force can break the clasps or the case itself.
  5. Skytex SP728 Speakers Replacement, Speakers: passo 5, imagem 1 %32
    • Identify the connection location of the wires from the speakers.
  6. Skytex SP728 Speakers Replacement: passo 6, imagem 1 %32
    • Use a soldering iron to remove the speaker wires from the circuit board
  7. Skytex SP728 Speakers Replacement: passo 7, imagem 1 %32
    • Solder the new speakers to the correct location, making sure the red wire goes to the + and the black wire goes to the -.
Conclusão
Uma outra pessoa concluiu este guia.
Chris Nelson
Membro desde: 01/21/15
213 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 5-1, Brown Winter 2015 Membro de USF Tampa, Team 5-1, Brown Winter 2015
USFT-BROWN-W15S5G1
Membros da 4
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 100
