Ir para o conteúdo principal
Sky Thunder HD 8500WH Gear Replacement
O que você precisa
  1. Sky Thunder HD 8500WH Gear Replacement, Rotor Blade: passo 1, imagem 1 %32 Sky Thunder HD 8500WH Gear Replacement, Rotor Blade: passo 1, imagem 2 %32 Sky Thunder HD 8500WH Gear Replacement, Rotor Blade: passo 1, imagem 3 %32
    • Place the drone with the top side facing up.
    • Remove the blade cover.
    • Remove the rotor blade.
  2. Sky Thunder HD 8500WH Gear Replacement, Lockstitch: passo 2, imagem 1 %32 Sky Thunder HD 8500WH Gear Replacement, Lockstitch: passo 2, imagem 2 %32
    • Unscrew the 1cm screw holding in the blade lockstitch with the Phillips 0 Screwdriver.
    • Remove the blade lockstitch.
  3. Sky Thunder HD 8500WH Gear Replacement, Lower and Upper Body: passo 3, imagem 1 %32 Sky Thunder HD 8500WH Gear Replacement, Lower and Upper Body: passo 3, imagem 2 %32 Sky Thunder HD 8500WH Gear Replacement, Lower and Upper Body: passo 3, imagem 3 %32
    • Lay down the drone so the battery side is facing up.
    • Unscrew all 5 .8cm screws on each arm of the drone with the Phillips 0 Screwdriver.
    • Repeat previous bullet for each arm (20 screws in total).
  4. Sky Thunder HD 8500WH Gear Replacement: passo 4, imagem 1 %32 Sky Thunder HD 8500WH Gear Replacement: passo 4, imagem 2 %32
    • Using a bit of force, gently pull apart the lower and upper bodies.
    • Keep going until both parts are completely separated.
  5. Sky Thunder HD 8500WH Gear Replacement, Gear: passo 5, imagem 1 %32 Sky Thunder HD 8500WH Gear Replacement, Gear: passo 5, imagem 2 %32
    • Find the gear mechanism at the end of one of the drone arms.
    • Unscrew the two front .8cm screws with the Phillips 0 Screwdriver.
  6. Sky Thunder HD 8500WH Gear Replacement: passo 6, imagem 1 %32 Sky Thunder HD 8500WH Gear Replacement: passo 6, imagem 2 %32
    • Remove the white spacer.
    • Remove the red spacer.
  7. Sky Thunder HD 8500WH Gear Replacement: passo 7, imagem 1 %32
    • Pull the gear out from the bottom of the holding mechanism.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 11
Duração total: 146
