Ir para o conteúdo principal
Sky 6.0Q Top Motherboard Replacement
O que você precisa
  1. Sky 6.0Q Top Motherboard Replacement, Top Motherboard: passo 1, imagem 1 %32
    • Use the #00 Phillips screwdriver to remove the two 3 mm screws at the bottom of the backplate.
    • Pry off the back plate with the spudger.
  2. Sky 6.0Q Top Motherboard Replacement: passo 2, imagem 1 %32
    • After removing back panel, remove all ten 3mm screws with the #00 Phillips screwdriver from the black plastic casing so it can be removed.
  3. Sky 6.0Q Top Motherboard Replacement: passo 3, imagem 1 %32 Sky 6.0Q Top Motherboard Replacement: passo 3, imagem 2 %32
    • Use the plastic opening tool to help pry up the plastic backing.
    • Once loose, remove the plastic backing to expose underlying electronic components.
  4. Sky 6.0Q Top Motherboard Replacement: passo 4, imagem 1 %32
    • Use the spudger disconnect the gold cord extending from the battery to the top electronic board.
  5. Sky 6.0Q Top Motherboard Replacement: passo 5, imagem 1 %32 Sky 6.0Q Top Motherboard Replacement: passo 5, imagem 2 %32 Sky 6.0Q Top Motherboard Replacement: passo 5, imagem 3 %32
    • Use the nylon spudger to help pry up the three top motherboard attachments.
    • See all three pictures for three attachment locations.
    • To reattach top motherboard connections gently press piece back in place.
  6. Sky 6.0Q Top Motherboard Replacement: passo 6, imagem 1 %32
    • Use the #00 Phillips screwdriver to remove the three 3 mm screws attaching the top motherboard.
  7. Sky 6.0Q Top Motherboard Replacement: passo 7, imagem 1 %32
    • Once the screws are removed, gently lift the top motherboard and replace.
Conclusão
Uma outra pessoa concluiu este guia.
Monica Difato
Membro desde: 11/06/18
429 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S1-G3, Hovde Fall 2018 Membro de IUPUI, Team S1-G3, Hovde Fall 2018
IUPUI-HOVDE-F18S1G3
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 18
Duração total: 475
