Ir para o conteúdo principal
Sky 6.0Q Battery Replacement
O que você precisa
  1. Sky 6.0Q Battery Replacement, Battery: passo 1, imagem 1 %32
    • Use the #00 Phillips screwdriver to remove the two 3 mm screws at the bottom of the backplate.
    • Pry off the back plate with the spudger.
  2. Sky 6.0Q Battery Replacement: passo 2, imagem 1 %32
    • After removing back panel, remove all ten 3mm screws with the #00 Phillips screwdriver from the black plastic casing so it can be removed.
  3. Sky 6.0Q Battery Replacement: passo 3, imagem 1 %32 Sky 6.0Q Battery Replacement: passo 3, imagem 2 %32
    • Use the plastic opening tool to help pry up the plastic backing.
    • Once loose, remove the plastic backing to expose underlying electronic components.
  4. Sky 6.0Q Battery Replacement: passo 4, imagem 1 %32
    • Disconnect the gold cord extending from the battery to the top electronic board.
    • Use the nylon spudger to help pry up the battery attachment.
    • To reattach the gold cord and battery attachment connection, gently press piece back in place.
  5. Sky 6.0Q Battery Replacement: passo 5, imagem 1 %32
    • Use the nylon spudger to get underneath the battery and separate it from the phone back.
    • There is a white, milky adhesive so be careful to not rip or puncture the battery during removal.
  6. Sky 6.0Q Battery Replacement: passo 6, imagem 1 %32
    • Once separated, remove battery and replace with a new battery.
Conclusão
Monica Difato
Membro desde: 11/06/18
429 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S1-G3, Hovde Fall 2018 Membro de IUPUI, Team S1-G3, Hovde Fall 2018
IUPUI-HOVDE-F18S1G3
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 36
Duração total: 2,416
