Ir para o conteúdo principal
Skullcandy Mix Master DJ Mylar Driver Replacement
O que você precisa
  1. Skullcandy Mix Master DJ Mylar Driver Replacement, Mylar Driver: passo 1, imagem 1 %32 Skullcandy Mix Master DJ Mylar Driver Replacement, Mylar Driver: passo 1, imagem 2 %32 Skullcandy Mix Master DJ Mylar Driver Replacement, Mylar Driver: passo 1, imagem 3 %32
    • With the plastic opening tool, separate the padded ear cup from the main speaker component.
    • Make sure to fold the ear cup inward to avoid getting in the way of the opposite side.
  2. Skullcandy Mix Master DJ Mylar Driver Replacement: passo 2, imagem 1 %32
    • Using your screw driver, remove the six Philips 2mm screws located on the chrome ring.
  3. Skullcandy Mix Master DJ Mylar Driver Replacement: passo 3, imagem 1 %32 Skullcandy Mix Master DJ Mylar Driver Replacement: passo 3, imagem 2 %32
    • Using your screw driver, remove the four 3mm Phillips screws located on the grey speaker.
    • Remove the driver from the gray speaker assembly.
    • Carefully remove the driver assembly since there are wires connected to the headphone jack, headband, and mute button.
  4. Skullcandy Mix Master DJ Mylar Driver Replacement: passo 4, imagem 1 %32 Skullcandy Mix Master DJ Mylar Driver Replacement: passo 4, imagem 2 %32
    • Using your screw driver, remove the two 2mm Phillips screws located on the circuit panel of the audio jack.
    • Carefully separate the jack from the ear cup casing.
    • If you are working on the right ear cup, the mute button circuit board may be difficult to remove.
  5. Skullcandy Mix Master DJ Mylar Driver Replacement: passo 5, imagem 1 %32 Skullcandy Mix Master DJ Mylar Driver Replacement: passo 5, imagem 2 %32
    • The Mylar driver is connected to several small circuit boards by soldered wires. It can only be removed by cutting the connecting wires.
    • Do not pull the driver away too fast since there are wires connecting the driver to the ear cup.
    • Soldering Guide: https://www.youtube.com/watch?v=urGB_IUX...
Conclusão
Uma outra pessoa concluiu este guia.
Sean Herlihy
Membro desde: 03/30/15
117 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 1-3, Shastany Spring 2015 Membro de UMass Dartmouth, Team 1-3, Shastany Spring 2015
UMASSD-SHASTANY-S15S1G3
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 1,487
