Ir para o conteúdo principal
Skullcandy Crusher Wireless Folding Hinge Replacement
O que você precisa
  1. Skullcandy Crusher Wireless Folding Hinge Replacement, Folding Hinge: passo 1, imagem 1 %32 Skullcandy Crusher Wireless Folding Hinge Replacement, Folding Hinge: passo 1, imagem 2 %32 Skullcandy Crusher Wireless Folding Hinge Replacement, Folding Hinge: passo 1, imagem 3 %32
    • Extend and fold the hinge of the headphones you are trying to replace.
  2. Skullcandy Crusher Wireless Folding Hinge Replacement: passo 2, imagem 1 %32 Skullcandy Crusher Wireless Folding Hinge Replacement: passo 2, imagem 2 %32 Skullcandy Crusher Wireless Folding Hinge Replacement: passo 2, imagem 3 %32
    • Remove two 14 mm Torx T6 screws on the underside of the headband.
  3. Skullcandy Crusher Wireless Folding Hinge Replacement: passo 3, imagem 1 %32 Skullcandy Crusher Wireless Folding Hinge Replacement: passo 3, imagem 2 %32 Skullcandy Crusher Wireless Folding Hinge Replacement: passo 3, imagem 3 %32
    • Pry the speaker away from the headband with a slight force.
  4. Skullcandy Crusher Wireless Folding Hinge Replacement: passo 4, imagem 1 %32 Skullcandy Crusher Wireless Folding Hinge Replacement: passo 4, imagem 2 %32 Skullcandy Crusher Wireless Folding Hinge Replacement: passo 4, imagem 3 %32
    • Remove two 5 mm Phillips #1 screws on the underside of the headband.
  5. Skullcandy Crusher Wireless Folding Hinge Replacement: passo 5, imagem 1 %32 Skullcandy Crusher Wireless Folding Hinge Replacement: passo 5, imagem 2 %32
    • Remove the top plastic part of the hinge.
Conclusão
10 outras pessoas executaram este guia.
Val
Membro desde: 03/31/22
1.125 Reputação
Autoria de 6 guias
Equipe
7 comentários
Hello. Any idea where can i buy the folding hinge from? thx!
Liviu - Responder
Hi, Like the explanation but can you tell me where to buy tge folding hinge?
Menno de Gier - Responder
I'm 3D printing these here https://www.ebay.co.uk/itm/364153346438
Stronger than original.
Eatfire - Responder
This is my alternative solution, albeit a temporary one. Sharing for people that end up here through search engines.
I figured out a temporary fix. I am posting this for others arriving here from search engines and the like. I assume OP's problem has long been solved. My fix is based on somebody else's fix.
I have 3D printed parts on the way, but my 'design' may actually press down on my ears better than the original. 🤔
What you'll need:
-Tie rip 2 mm
-Tie rip 4 mm
-Drill + 1,5 mm drillbit for metal
-Strong thin elastic.
-Pliers (for making sure the tierips are real tight.)
https://guide-images.cdn.ifixit.com/igi/...
Cus7od35 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 45
Últimos 30 dias: 198
Duração total: 9,242
