Ir para o conteúdo principal
Skullcandy Air Raid Speakers Replacement
O que você precisa
  1. Skullcandy Air Raid Speakers Replacement, Rubber Cover: passo 1, imagem 1 %32
    • Starting with the corners, gently pull the rubber cover off of the device.
  2. Skullcandy Air Raid Speakers Replacement, Handle: passo 2, imagem 1 %32
    • Using the T-6 hexagonal screwdriver, unscrew the four 10mm #6 hex screws on the right side of the device.
    • Remove the handle from the device.
  3. Skullcandy Air Raid Speakers Replacement, Front Plate: passo 3, imagem 1 %32
    • Unscrew the two screws on the left side of the device using the phillips #00 screwdriver.
    • One 5mm Phillips screw.
    • One 8mm Phillips screw.
  4. Skullcandy Air Raid Speakers Replacement: passo 4, imagem 1 %32
    • Gently pull the sides of the front plate outwards from the device.
    • Pull up on the front plate to remove it from the device.
  5. Skullcandy Air Raid Speakers Replacement, Speakers: passo 5, imagem 1 %32
    • Using a #000 Phillips Screwdriver, unscrew the four 0.8 cm Philips screws from each corner of the speaker you are replacing (eight 0.8 Philips screws total).
  6. Skullcandy Air Raid Speakers Replacement: passo 6, imagem 1 %32
    • Using the plastic opening tool, pry around edges of speaker to loosen glue contact with front plate.
    • If you are unable to loosen glue contact using the plastic opening tool, use a heat gun to assist in removal.
  7. Skullcandy Air Raid Speakers Replacement: passo 7, imagem 1 %32
    • Lift the speaker out of the device.
    • Be aware of the connection with the ribbon cable.
    • For reassembly, ensure proper orientation of the cable plug.
  8. Skullcandy Air Raid Speakers Replacement: passo 8, imagem 1 %32
    • Firmly pull on the end of the ribbon cable to disconnect the speaker from the motherboard.
  9. Skullcandy Air Raid Speakers Replacement, Desolder Wires: passo 9, imagem 1 %32
    • Desolder the black and red wires from the speaker.
    • The red wire is for the left speaker and the black is for the right speaker.
Conclusão
Um comentário
Where can I buy the replacement speaker?
Luis Polino - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 11
Duração total: 1,580
