Introdução
If your Skullcandy Air Raid will not maintain power even after charging, it may be time to replace the battery.
O que você precisa
Starting with the corners, gently pull the rubber cover off of the device.
Using the T-6 hexagonal screwdriver, unscrew the four 10mm #6 hex screws on the right side of the device.
Remove the handle from the device.
Unscrew the two screws on the left side of the device using the phillips #00 screwdriver.
One 5mm Phillips screw.
One 8mm Phillips screw.
Using a #000 Philips Screwdriver, unscrew the four 8 mm Philips screws from each corner of both speakers (eight 8 mm Philips screws total).
Using a Phillips #00 Precision Screwdriver, unscrew two 6 mm screws from the middle of the panel, above and below volume buttons.
Using a Phillips #00 Precision Screwdriver, unscrew two 6 mm screws from the button motherboard.
Pull the black ribbon cord attachment away from the motherboard.
Pull on the cable until it releases from the back of the motherboard.
Using a Phillips #00 Precision Screwdriver, unscrew two 8 mm screws.
Lift off the back panel.
How do you pull off the back panel? Those two parts are really stuck to each other.
There's four additional screws in the corners! How did you miss that?
Pull on the ribbon cable that connects the battery to the motherboard until the connector releases.
Pull battery straight out until it is completely out of device.
Battery: 2000 mAh - 3.7v - 7.4Wh. Part number (printed on battery) AEC553450-2P.
Can you please tell me where the white wire in from the battery terminal goes please .. I have a red a black and a white wire and the white wire is not connected anywhere .. i have just bought 3 of these skull air raids as faulty and would like to repair them for my kids .. many thanks
Great instructions. Very helpful. But is there any place to find this battery?
6 outras pessoas executaram este guia.
6 comentários
Hi, my name is Alex, and i have the same problem. The battery does not work anymore, but i don't know where can i find a replacement, and what is the its name. Or mabe something similar? I live in Romania so i need mabe an international online store to buy it. Thank you! My email is stanciualex_e@ yahoo.com
What is the type of battery?
I have the same issue. I want to acquire a replacement.
It is a rechargeable battery Model AEC553450-2P / 2000mA 3.7V 7.4Wh.
It there anybody out there who could help us I will appreciate it very much
I also need a battery, have you found one?
ive been trying to fix this sme exact speaker and it is unessary to remove the speaker screews, so id recoment leaving those in place
