Ir para o conteúdo principal
SkullCandy Hesh Size Adjuster Replacement
O que você precisa
  1. SkullCandy Hesh Size Adjuster Replacement, Determine the damage: passo 1, imagem 1 %32 SkullCandy Hesh Size Adjuster Replacement, Determine the damage: passo 1, imagem 2 %32
    • Locate the break in the device.
  2. SkullCandy Hesh Size Adjuster Replacement: passo 2, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove the two 9 mm screws from the bottom inner casing beneath the break.
  3. SkullCandy Hesh Size Adjuster Replacement: passo 3, imagem 1 %32
    • Remove the bottom inner casing to reveal the wire compartment and the port where the slider inserts.
  4. SkullCandy Hesh Size Adjuster Replacement: passo 4, imagem 1 %32 SkullCandy Hesh Size Adjuster Replacement: passo 4, imagem 2 %32
    • Cover the detached slider port in a generous layer of Plasti Dip, which works like glue. Also coat any exposed wire to seal the circuit.
  5. SkullCandy Hesh Size Adjuster Replacement: passo 5, imagem 1 %32
    • Realign the broken size adjuster into the port with the Plasti Dip so that it can be secured to the ear piece.
  6. SkullCandy Hesh Size Adjuster Replacement: passo 6, imagem 1 %32
    • Clamp the pieces in place by hand or with a binder clip until the Plasti Dip dries. Feel free to use a hair dryer on a low setting to speed up the process.
Conclusão
To reassemble your device, reattach the bottom inner casing with the Phillips #0 screwdriver and two removed screws.
Sarah Burk
Membro desde: 01/15/15
247 Reputação
Autoria de 3 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 20
Duração total: 833
