Introdução
This guide will outline all the steps necessary to reattach a SkullCandy Hesh size adjuster that's snapped. Exposed wires in this area will result in either a cessation in sound production, or sound being produced in only one side of the device. When troubleshooting sound problems, this is the last solution to check, as it requires the most time.
O que você precisa
To reassemble your device, reattach the bottom inner casing with the Phillips #0 screwdriver and two removed screws.
