Ir para o conteúdo principal
Skirt Lining Replacement
O que você precisa
  1. Skirt Lining Replacement, Lining: passo 1, imagem 1 %32 Skirt Lining Replacement, Lining: passo 1, imagem 2 %32
    • Cut out the old or damaged skirt lining. This can be done using a pair of scissors, or a razor blade/seam ripper if you have one.
    • Blades might give you a neater finish after this step but take longer to use.
    • Be careful when using sharp objects.
  2. Skirt Lining Replacement: passo 2, imagem 1 %32 Skirt Lining Replacement: passo 2, imagem 2 %32
    • After threading the needle, take some new lining (chiffon or silk material), iron it out, and make sure the lining isn't longer than the actual skirt.
  3. Skirt Lining Replacement: passo 3, imagem 1 %32 Skirt Lining Replacement: passo 3, imagem 2 %32 Skirt Lining Replacement: passo 3, imagem 3 %32
    • Gently insert the threaded needle. Be careful not to prick your finger.
    • Push through the skirt fabric from below.
    • Pull the needle all the way out to form a stitch.
  4. Skirt Lining Replacement: passo 4, imagem 1 %32
    • Continue with step 3 until you create stitches around the whole waistband of your skirt.
    • It should look somewhat like this when you make it halfway around the waistband of the skirt.
  5. Skirt Lining Replacement: passo 5, imagem 1 %32
    • Cut out extra fabric if you have any, and here's what the waistline of your skirt should look like.
    • Try it on!
Linha de Chegada
Uma outra pessoa concluiu este guia.
Rena
Membro desde: 01/11/24
121 Reputação
Autoria de 1 guia
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 35
Ao todo: 250
