Ir para o conteúdo principal
Skil X-Drive 18V Cordless Drill Model No. 2887 Handle Replacement
O que você precisa
  1. Skil X-Drive 18V Cordless Drill Model No. 2887 Handle Replacement, Un-clip Battery: passo 1, imagem 1 %32
    • Grip the drill. Locate the red locking switch on the back of the battery. Hold the switch down.
  2. Skil X-Drive 18V Cordless Drill Model No. 2887 Handle Replacement, Remove Battery: passo 2, imagem 1 %32 Skil X-Drive 18V Cordless Drill Model No. 2887 Handle Replacement, Remove Battery: passo 2, imagem 2 %32 Skil X-Drive 18V Cordless Drill Model No. 2887 Handle Replacement, Remove Battery: passo 2, imagem 3 %32
    • While holding down the red locking switch, slide the battery towards the back of the drill until the battery is fully removed from the drill.
  3. Skil X-Drive 18V Cordless Drill Model No. 2887 Handle Replacement, Remove Handle: passo 3, imagem 1 %32 Skil X-Drive 18V Cordless Drill Model No. 2887 Handle Replacement, Remove Handle: passo 3, imagem 2 %32 Skil X-Drive 18V Cordless Drill Model No. 2887 Handle Replacement, Remove Handle: passo 3, imagem 3 %32
    • Grip cordless drill firmly with left hand. Grip the cordless drill handle firmly with the right hand. Rotate the handle counterclockwise in order to remove the handle from the drill.
Conclusão
Sean
Membro desde: 09/23/14
282 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 2-3, Blackwell Fall 2014 Membro de USF Tampa, Team 2-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G3
Membros da 5
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 460
