Ir para o conteúdo principal
Skil X-Drive 18V Cordless Drill Model No. 2887 Battery Replacement
O que você precisa
  1. Skil X-Drive 18V Cordless Drill Model No. 2887 Battery Replacement, Un-clip Battery: passo 1, imagem 1 %32
    • Grip the drill. Locate the red locking switch on the back of the battery. Hold the switch down.
  2. Skil X-Drive 18V Cordless Drill Model No. 2887 Battery Replacement, Remove Battery: passo 2, imagem 1 %32 Skil X-Drive 18V Cordless Drill Model No. 2887 Battery Replacement, Remove Battery: passo 2, imagem 2 %32 Skil X-Drive 18V Cordless Drill Model No. 2887 Battery Replacement, Remove Battery: passo 2, imagem 3 %32
    • While holding down the red locking switch, slide the battery towards the back of the drill until the battery is fully removed from the drill.
Conclusão
4 outras pessoas executaram este guia.
Sean
Membro desde: 09/23/14
282 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 2-3, Blackwell Fall 2014 Membro de USF Tampa, Team 2-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G3
Membros da 5
Autoria de 9 guias
5 comentários
my battery is stuck in the drill any ideas
yonko99 - Responder
My battery is also stuck. I see no replies. What now?
Bobby Verdier - Responder
Thank you, it really was easy !!!!!
Betty - Responder
My battery is stuck too. I read on another forum to use a screwdriver and hammer.
I’m a girl, so don’t take my advice, but wondering if you could you spray it with WD-40 to loosen it up?
Amy Dionne - Responder
Have you been able to get it out? On mine the button was hard to get all the way down. I used both thumbs and was eventually able to get it down far enough to get it off. I bumped it on my leg to help loosen it. If you use a hammer I would suggest using a rubber mallet so you don’t damage the battery or the drill.
Once it’s off clean up the slides real good, spray some WD40 on them, then wipe off with a rag. That should help prevent it from getting stuck again. I would spray a little WD40 on the button and work it back and forth as well.
Hope this helps
Brian Harrod -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 25
Últimos 30 dias: 126
Duração total: 6,264
