Ir para o conteúdo principal
Skil 88 Motor Housing Replacement
O que você precisa
  1. Skil 88 Motor Housing Replacement, Disassembling Skil 88 Front Housing: passo 1, imagem 1 %32
    • On the front of the drill, remove the three 2" flathead screws connecting the front housing to the rear housing.
  2. Skil 88 Motor Housing Replacement: passo 2, imagem 1 %32 Skil 88 Motor Housing Replacement: passo 2, imagem 2 %32
    • Pull the front housing apart from the rear.
    • The motor and gears might fall out when you are pulling it apart.
  3. Skil 88 Motor Housing Replacement, Trigger Housing: passo 3, imagem 1 %32 Skil 88 Motor Housing Replacement, Trigger Housing: passo 3, imagem 2 %32
    • Use the socket wrench to remove the 0.5" length screw from the bottom of the handle.
  4. Skil 88 Motor Housing Replacement: passo 4, imagem 1 %32 Skil 88 Motor Housing Replacement: passo 4, imagem 2 %32 Skil 88 Motor Housing Replacement: passo 4, imagem 3 %32
    • Separate the cord from the handle.
  5. Skil 88 Motor Housing Replacement, Motor Housing: passo 5, imagem 1 %32 Skil 88 Motor Housing Replacement, Motor Housing: passo 5, imagem 2 %32
    • Remove the inner divider.
  6. Skil 88 Motor Housing Replacement: passo 6, imagem 1 %32
    • Remove the two 1" flathead screws located at the top and bottom of the motor housing.
  7. Skil 88 Motor Housing Replacement: passo 7, imagem 1 %32 Skil 88 Motor Housing Replacement: passo 7, imagem 2 %32
    • Pull the motor housing out.
    • The wires from the trigger housing should follow the motor housing.
  8. Skil 88 Motor Housing Replacement: passo 8, imagem 1 %32 Skil 88 Motor Housing Replacement: passo 8, imagem 2 %32
    • After you have placed the motor housing back into the drill during reassembly, thread the wires down to the handle using tweezers.
    • Plug the forked wire into the socket at the back of the motor housing using tweezers.
Conclusão
To continue reassembly, simply follow the guide backwards starting at step 2.
Matt
Membro desde: 10/10/10
365 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 5-17, Maness Fall 2010 Membro de Cal Poly, Team 5-17, Maness Fall 2010
CPSU-MANESS-F10S5G17
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 2,885
