Introdução
The LED screen is attached to the motherboard inside the casing. This guide will show how to detach the screen from the motherboard for replacement.
O que você precisa
Remove the plastic case in front of the socket using the spudger.
Hold the screen and gently pull in the direction of the cable to separate screen from the socket.
Quase terminado!
Conclusão
