Ir para o conteúdo principal
Single-Speed Bicycle Chain Replacement
O que você precisa
  1. Single-Speed Bicycle Chain Replacement, Chain: passo 1, imagem 1 %32 Single-Speed Bicycle Chain Replacement, Chain: passo 1, imagem 2 %32
    • Flip the bike upside down for easy access to the rear wheel and chain.
  2. Single-Speed Bicycle Chain Replacement: passo 2, imagem 1 %32 Single-Speed Bicycle Chain Replacement: passo 2, imagem 2 %32
    • Use either an Allen or crescent wrench to loosen the nuts of the rear wheel of the bike. Make sure to do this on both sides of the wheel.
    • This step will require a 5mm Allen wrench or a crescent wrench, depending on the type of wheels you have.
  3. Single-Speed Bicycle Chain Replacement: passo 3, imagem 1 %32 Single-Speed Bicycle Chain Replacement: passo 3, imagem 2 %32
    • Place the chain breaker tool over the old chain.
    • Insert a link of the old chain into the chain breaker tool.
  4. Single-Speed Bicycle Chain Replacement: passo 4, imagem 1 %32 Single-Speed Bicycle Chain Replacement: passo 4, imagem 2 %32 Single-Speed Bicycle Chain Replacement: passo 4, imagem 3 %32
    • Turn the knob on the chain breaker tool until the pin within the chain has popped out.
    • Remove the old chain.
    • This step may take some finesse to ensure that the pin falls out.
  5. Single-Speed Bicycle Chain Replacement: passo 5, imagem 1 %32 Single-Speed Bicycle Chain Replacement: passo 5, imagem 2 %32
    • Unbox the new chain and place it on the chain ring.
    • Align the rings with the gears to ensure a proper fit.
  6. Single-Speed Bicycle Chain Replacement: passo 6, imagem 1 %32 Single-Speed Bicycle Chain Replacement: passo 6, imagem 2 %32 Single-Speed Bicycle Chain Replacement: passo 6, imagem 3 %32
    • Wrap the chain around the cog of the rear wheel and bring the two ends of the chain together.
    • The chain should be long enough so that it can move up and down ~1/2 inch when secured.
    • Remove the excess chain using the chain breaker tool. Refer to steps 3 and 4 for how to use the chain breaker tool.
  7. Single-Speed Bicycle Chain Replacement: passo 7, imagem 1 %32 Single-Speed Bicycle Chain Replacement: passo 7, imagem 2 %32 Single-Speed Bicycle Chain Replacement: passo 7, imagem 3 %32
    • Locate the master link of the chain.
    • A master link is a single removable link segment on a bike chain. It connects the two ends of the chain together.
    • Insert the link pins into the two ends of the chain.
  8. Single-Speed Bicycle Chain Replacement: passo 8, imagem 1 %32 Single-Speed Bicycle Chain Replacement: passo 8, imagem 2 %32
    • Place the link face onto the link pins.
    • The chain is now secured.
  9. Single-Speed Bicycle Chain Replacement: passo 9, imagem 1 %32 Single-Speed Bicycle Chain Replacement: passo 9, imagem 2 %32 Single-Speed Bicycle Chain Replacement: passo 9, imagem 3 %32
    • Once the chain is on, pull the rear wheel back.
    • Tighten the nut on the drive side (right side) of the rear wheel.
    • The drive side of a bike is the side with the gears. This is usually on the right side, as seen in this model.
  10. Single-Speed Bicycle Chain Replacement: passo 10, imagem 1 %32 Single-Speed Bicycle Chain Replacement: passo 10, imagem 2 %32
    • Push the front end of the rear wheel to the non-drive side (left side) of the wheel. This pulls on the chain, creating tension.
    • Tighten the nut on the non-drive side (left side) of the wheel.
  11. Single-Speed Bicycle Chain Replacement: passo 11, imagem 1 %32
    • Repeat the previous step with the drive side (right side) until the wheel is tightened.
    • Ensure that both nuts are tightened evenly.
  12. Single-Speed Bicycle Chain Replacement: passo 12, imagem 1 %32 Single-Speed Bicycle Chain Replacement: passo 12, imagem 2 %32 Single-Speed Bicycle Chain Replacement: passo 12, imagem 3 %32
    • Check the tension in the gear.
    • It is good to have about half an inch of play in the chain in both directions.
Conclusão
SaniaHey
Membro desde: 01/31/24
205 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 1-7, Andersen Winter 2024 Membro de UC Davis, Team 1-7, Andersen Winter 2024
UCD-ANDERSEN-W24S1G7
Membros da 3
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 34
Duração total: 133
