Ir para o conteúdo principal
Singing Machine Shine Duets LED Lights Replacement
O que você precisa
  1. Singing Machine Shine Duets LED Lights Replacement, Singing Machine Shine Duets Shell Dissassembly: passo 1, imagem 1 %32 Singing Machine Shine Duets LED Lights Replacement, Singing Machine Shine Duets Shell Dissassembly: passo 1, imagem 2 %32 Singing Machine Shine Duets LED Lights Replacement, Singing Machine Shine Duets Shell Dissassembly: passo 1, imagem 3 %32
    • Remove the 10 mm screws on either side of the machine using a Phillips #1 screwdriver.
  2. Singing Machine Shine Duets LED Lights Replacement: passo 2, imagem 1 %32 Singing Machine Shine Duets LED Lights Replacement: passo 2, imagem 2 %32 Singing Machine Shine Duets LED Lights Replacement: passo 2, imagem 3 %32
    • Remove the three 8 mm screws with a Phillips #0 screwdriver.
  3. Singing Machine Shine Duets LED Lights Replacement: passo 3, imagem 1 %32 Singing Machine Shine Duets LED Lights Replacement: passo 3, imagem 2 %32 Singing Machine Shine Duets LED Lights Replacement: passo 3, imagem 3 %32
    • Use the opening tool or your hands to carefully pry open the now-loosened top panel.
    • The top portion of the shell is open, and the inside of the device is now accessible.
  4. Singing Machine Shine Duets LED Lights Replacement, LED Lights: passo 4, imagem 1 %32 Singing Machine Shine Duets LED Lights Replacement, LED Lights: passo 4, imagem 2 %32 Singing Machine Shine Duets LED Lights Replacement, LED Lights: passo 4, imagem 3 %32
    • Remove the 10 mm screw from the LED lightboard using a Phillips #0 screwdriver.
  5. Singing Machine Shine Duets LED Lights Replacement: passo 5, imagem 1 %32 Singing Machine Shine Duets LED Lights Replacement: passo 5, imagem 2 %32 Singing Machine Shine Duets LED Lights Replacement: passo 5, imagem 3 %32
    • Carefully remove the lightboard from the device, taking care not to damage any pins.
    • To reassemble, connect the pins on the lightboard to the motherboard.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 47
