Ir para o conteúdo principal
Singing Machine Shine Duets Audio/Power Jack Replacement
O que você precisa
  1. Singing Machine Shine Duets Audio/Power Jack Replacement, Singing Machine Shine Duets Shell Dissassembly: passo 1, imagem 1 %32 Singing Machine Shine Duets Audio/Power Jack Replacement, Singing Machine Shine Duets Shell Dissassembly: passo 1, imagem 2 %32 Singing Machine Shine Duets Audio/Power Jack Replacement, Singing Machine Shine Duets Shell Dissassembly: passo 1, imagem 3 %32
    • Remove the 10 mm screws on either side of the machine using a Phillips #1 screwdriver.
  2. Singing Machine Shine Duets Audio/Power Jack Replacement: passo 2, imagem 1 %32 Singing Machine Shine Duets Audio/Power Jack Replacement: passo 2, imagem 2 %32 Singing Machine Shine Duets Audio/Power Jack Replacement: passo 2, imagem 3 %32
    • Remove the three 8 mm screws with a Phillips #0 screwdriver.
  3. Singing Machine Shine Duets Audio/Power Jack Replacement: passo 3, imagem 1 %32 Singing Machine Shine Duets Audio/Power Jack Replacement: passo 3, imagem 2 %32 Singing Machine Shine Duets Audio/Power Jack Replacement: passo 3, imagem 3 %32
    • Use the opening tool or your hands to carefully pry open the now-loosened top panel.
    • The top portion of the shell is open, and the inside of the device is now accessible.
  4. Singing Machine Shine Duets Audio/Power Jack Replacement, Motherboard: passo 4, imagem 1 %32
    • The motherboard is located right behind the control buttons.
  5. Singing Machine Shine Duets Audio/Power Jack Replacement: passo 5, imagem 1 %32 Singing Machine Shine Duets Audio/Power Jack Replacement: passo 5, imagem 2 %32
    • Remove the two screws holding the LED board in place.
  6. Singing Machine Shine Duets Audio/Power Jack Replacement: passo 6, imagem 1 %32 Singing Machine Shine Duets Audio/Power Jack Replacement: passo 6, imagem 2 %32
    • Remove both LED boards from their pins.
  7. Singing Machine Shine Duets Audio/Power Jack Replacement: passo 7, imagem 1 %32 Singing Machine Shine Duets Audio/Power Jack Replacement: passo 7, imagem 2 %32
    • Detach the white cable from its connector on the motherboard.
  8. Singing Machine Shine Duets Audio/Power Jack Replacement: passo 8, imagem 1 %32 Singing Machine Shine Duets Audio/Power Jack Replacement: passo 8, imagem 2 %32
    • Carefully disconnect this red-and-black wire from the motherboard.
  9. Singing Machine Shine Duets Audio/Power Jack Replacement: passo 9, imagem 1 %32 Singing Machine Shine Duets Audio/Power Jack Replacement: passo 9, imagem 2 %32
    • Remove the thicker red-and-black wire from its socket on the motherboard.
  10. Singing Machine Shine Duets Audio/Power Jack Replacement: passo 10, imagem 1 %32 Singing Machine Shine Duets Audio/Power Jack Replacement: passo 10, imagem 2 %32 Singing Machine Shine Duets Audio/Power Jack Replacement: passo 10, imagem 3 %32
    • Disconnect the red port on the board which holds all of the external plugs
    • Disconnect the white wires from the board.
  11. Singing Machine Shine Duets Audio/Power Jack Replacement: passo 11, imagem 1 %32 Singing Machine Shine Duets Audio/Power Jack Replacement: passo 11, imagem 2 %32
    • Remove eleven 8 mm screws from the motherboard with a Phillips #0 screwdriver.
  12. Singing Machine Shine Duets Audio/Power Jack Replacement: passo 12, imagem 1 %32 Singing Machine Shine Duets Audio/Power Jack Replacement: passo 12, imagem 2 %32 Singing Machine Shine Duets Audio/Power Jack Replacement: passo 12, imagem 3 %32
    • Remove the motherboard from the shell.
  13. Singing Machine Shine Duets Audio/Power Jack Replacement, Audio/Power Jack: passo 13, imagem 1 %32 Singing Machine Shine Duets Audio/Power Jack Replacement, Audio/Power Jack: passo 13, imagem 2 %32
    • Remove both screws from the board.
    • Use caution when removing the screw in between the two ports.
  14. Singing Machine Shine Duets Audio/Power Jack Replacement: passo 14, imagem 1 %32 Singing Machine Shine Duets Audio/Power Jack Replacement: passo 14, imagem 2 %32
    • Remove the board from the shell.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 37
Duração total: 238
