Introdução
This is a quick tutorial on how to replace the brass bushing by Bearing.
O que você precisa
Just push or pull the middle tube then push the bushing out.
Add the bearing into the hole flange facing "outside".
Add a M5 1mm washing on the bearing, on the flanged part (facing outside).
Just place the spring back into place. You may use a little flat screw driver for help.
4 outras pessoas executaram este guia.
10 comentários
Washers need to be 1mm or 0,1mm ? https://www.loziska-rc.com/85440090?sear... will these be good?
1mm exactly, that's about the space left between the bearing and the plate.
edit : Yes those should be fine.
Hi,
You mention F605ZZ (14x5x4mm) but all F605ZZ I find are 14x5x5mm.
Are you sure yours are 4mm wide ?
Thanks in advance and excellent idea and guide by the way !
they are indeed 5mm wide, my bad. I will correct the post !
