Ir para o conteúdo principal
Sigrow Soil Pro + Assembly
O que você precisa
  1. Sigrow Soil Pro + Assembly, Gather materials: passo 1, imagem 1 %32 Sigrow Soil Pro + Assembly, Gather materials: passo 1, imagem 2 %32 Sigrow Soil Pro + Assembly, Gather materials: passo 1, imagem 3 %32
    • PCB RR02 or higher 'coated
    • Sigrow Soil Sensor
    • (Top left to bottom right) Case Body +, hat +, solar, bottom inner plate +, fan holder.
    • Sunon Fan 5VDC
    • Solar panel 110x80
    • Tools (top-left to bottom right) : tin, soldering station, flat head screw driver, cable peeler, pliers glue gun (optional).
    • Cable double insulaton: +6 wires, 20 cm
  2. Sigrow Soil Pro + Assembly, Prepare cable solar panel to PCB: passo 2, imagem 1 %32 Sigrow Soil Pro + Assembly, Prepare cable solar panel to PCB: passo 2, imagem 2 %32 Sigrow Soil Pro + Assembly, Prepare cable solar panel to PCB: passo 2, imagem 3 %32
    • Cable length is aprox 20-22 cm
    • Peel both ends, keep the non-peeled part short
    • Group them, twist and solder them together
    • On the opposite side you will only keep two colours: black and yellow
  3. Sigrow Soil Pro + Assembly, Solder cable solar panel: passo 3, imagem 1 %32 Sigrow Soil Pro + Assembly, Solder cable solar panel: passo 3, imagem 2 %32 Sigrow Soil Pro + Assembly, Solder cable solar panel: passo 3, imagem 3 %32
    • Solder
    • Remove the plastic sheet
    • Slide solar panel in parasol
  4. Sigrow Soil Pro + Assembly, Fan mount: passo 4, imagem 1 %32
    • Insert fan in fan holder
    • Pay attention to the fan air flow direction, it should be upwards
  5. Sigrow Soil Pro + Assembly, Peripherals: passo 5, imagem 1 %32 Sigrow Soil Pro + Assembly, Peripherals: passo 5, imagem 2 %32
    • From top to bottom:
    • Solar Panel mounted and with cable soldered (side with Sigrow letters)
    • Fan (cable enters from bottom)
    • Soil Sensor (cable enters from Sigrow 3 circles logo side)
  6. Sigrow Soil Pro + Assembly, Attach fan holder to main case+: passo 6, imagem 1 %32 Sigrow Soil Pro + Assembly, Attach fan holder to main case+: passo 6, imagem 2 %32
    • Fan holder should be inserted in main body case by pressure
    • If there's not a tight fit there are 2 options:
    • Option 1: Request a new fan holder
    • Option 2: Use the hot glue gun.
    • tight fit could be interpreted as: "if with very hard shaken the fan holder and main case will not disconnect and stay solidly attached.'
  7. Sigrow Soil Pro + Assembly, Bottom inner plate: passo 7, imagem 1 %32 Sigrow Soil Pro + Assembly, Bottom inner plate: passo 7, imagem 2 %32
    • Rectangular gap (for temperature humidity sensor) goes slightly in the left.
    • Bottom right tiny circular hole is for the fan cables
  8. Sigrow Soil Pro + Assembly, Confirm orientation: passo 8, imagem 1 %32 Sigrow Soil Pro + Assembly, Confirm orientation: passo 8, imagem 2 %32
    • Sigrow 3 circles side-> Soil Sensor
    • Letter side -> Solar panel
  9. Sigrow Soil Pro + Assembly, Soil Sensor connection: passo 9, imagem 1 %32 Sigrow Soil Pro + Assembly, Soil Sensor connection: passo 9, imagem 2 %32 Sigrow Soil Pro + Assembly, Soil Sensor connection: passo 9, imagem 3 %32
    • Insert cables into connector, check in 3rd image in this step that the ports are open
    • Use pliers to cut white cable
  10. Sigrow Soil Pro + Assembly, Solder fan cables: passo 10, imagem 1 %32 Sigrow Soil Pro + Assembly, Solder fan cables: passo 10, imagem 2 %32
    • Black ground
    • Red positive
    • Cut with pliers cable excess from behind
  11. Sigrow Soil Pro + Assembly, Solder solar panel cables to pcb: passo 11, imagem 1 %32 Sigrow Soil Pro + Assembly, Solder solar panel cables to pcb: passo 11, imagem 2 %32 Sigrow Soil Pro + Assembly, Solder solar panel cables to pcb: passo 11, imagem 3 %32
    • Cables enter from the back of the PCB
    • Yellow is positive
    • Black is negative (closer to the edge)
    • Cut with pliers cable and tin excess
    • Soldering station is very hot, dont touch it with your hands
  12. Sigrow Soil Pro + Assembly, Insert PCB in case - Cable details: passo 12, imagem 1 %32 Sigrow Soil Pro + Assembly, Insert PCB in case - Cable details: passo 12, imagem 2 %32
    • It's great to leave some extra cables in good shape
    • ~10 cm for the soil sensor bended as inverted-U
    • Twist the fan cable (it's very long) and bend as inverted-U
    • if PCB doesn't slide down with a gentle push or slides out too easy when case is upside down new case should be requested.
  13. Sigrow Soil Pro + Assembly, Closing the case: passo 13, imagem 1 %32 Sigrow Soil Pro + Assembly, Closing the case: passo 13, imagem 2 %32
    • After sliding PCB in, connect the solar parasol and the hat +
    • If the fit is not great inform Sigrow senior technician
  14. Sigrow Soil Pro + Assembly: passo 14, imagem 1 %32
    • Congrats, you have completed a Soil Pro+
    • Please request from your Senior technician the latest packaging guidelines
Conclusão
In case of doubt contact manufacturing@sigrow.com
Sigrow
Membro desde: 05/14/20
1.075 Reputação
Autoria de 5 guias
Equipe
Sigrow Membro de Sigrow
Community
3 Membros
Autoria de 5 guias
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 236
