Introdução
1°/ Remove the 4 screws on the bottom (take care because to one, the blue screw, of them is shorter than others).
  1. 1°/ Remove the 4 screws at the bottom (take care because to one of them, blue screw, is shorter than the others)
    • 1°/ Remove the 4 screws at the bottom (take care because to one of them, blue screw, is shorter than the others)
  2. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  3. Remove the 4 screws around the steel ring in order to disassemble the captor (blue area) and the plastic ring (red area) which is insert inside the steel ring and behind the captor Remove the 4 screws around the steel ring in order to disassemble the captor (blue area) and the plastic ring (red area) which is insert inside the steel ring and behind the captor
    • Remove the 4 screws around the steel ring in order to disassemble the captor (blue area) and the plastic ring (red area) which is insert inside the steel ring and behind the captor
  4. Remove the steel ring (red area) due to a vertical translation (take care with the vertical sheet, in green area metal, which is used to open the diaphragm)
    • Remove the steel ring (red area) due to a vertical translation (take care with the vertical sheet, in green area metal, which is used to open the diaphragm)
Conclusão
8 outras pessoas concluíram este guia.
Greg
349 reputação
Autoria de 1 guia
Visualizar Estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 53
Todo: 2,374
