O que você precisa
Remove all attachments such as water tank, pulp drawer, brew group.
Remove the coffee container lid and take out all the coffee beans.
Lay the machine on its side with the water tank side facing up.
The side panel is essentially held on the ground by five strong catches. Pry up the pegs with a strong prying tool. It's pretty difficult and you need a lot of strength.
If the catches are loose, you can pull the side panel away from below. But it's still stuck in other places.
Use a plastic tool to pry the top cover up a few millimeters and lift off the side panel. Most of the time it's still stuck, especially at the front edge, you have to pull hard.
If you haven't already done so: Remove the two plastic covers over the cables and the electronics box.
Unscrew the four Torx T20 screws holding the ceramic valve together.
Carefully disassemble the valve into two parts.
Take out the ceramic discs very carefully. If they fall, they may break!
Slide the slices apart. Clean and descale them.
Carefully detach and clean the two black rubber seals. Note how they are installed.
Blow into all canals and check that they are clear.
If the valve does not find a position, one or both microswitches are defective. Then you have to exchange them. These are easily available standard types from SAIA, the type designation is printed on them.
Follow the steps in reverse order to reassemble your device.
Um agradecimento especial a esses tradutores:
100%
oldturkey03 está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
