Ir para o conteúdo principal
Siemens A56 SIM Card Replacement
O que você precisa
  1. Siemens A56 SIM Card Replacement, Battery: passo 1, imagem 1 %32
    • Press down on the grooved area firmly in the direction of arrow #1.
    • While maintaining the downwards pressure, push the back cover in the direction of arrow #2 until the back cover slides off.
    • Photos taken from: http://theinformr.com/uploads/manuals/si...
  2. Siemens A56 SIM Card Replacement: passo 2, imagem 1 %32
    • Turn off the phone before removing the battery to avoid damage.
    • Press the latch on the battery in the direction of arrow #3.
    • Lift battery at the cutout on the side of the phone, then tilt upwards and remove.
    • It may be necessary to use the tip of a fingernail or a plastic lifting tool to remove the battery.
  3. Siemens A56 SIM Card Replacement, SIM Card: passo 3, imagem 1 %32 Siemens A56 SIM Card Replacement, SIM Card: passo 3, imagem 2 %32 Siemens A56 SIM Card Replacement, SIM Card: passo 3, imagem 3 %32
    • With the phone turned onto its backside, gently slide the metal clasp up to unlock the SIM card.
    • It may be easier to move the clasp with a plastic opening tool, but it is not required.
    • The SIM card will spring up once the clasp is released.
    • Remove the SIM card from phone.
  4. Siemens A56 SIM Card Replacement: passo 4, imagem 1 %32 Siemens A56 SIM Card Replacement: passo 4, imagem 2 %32 Siemens A56 SIM Card Replacement: passo 4, imagem 3 %32
    • To replace the SIM card, insert the card back into the slot.
    • While pressing the SIM card with one finger, slide the metal clasp down to lock the card in place.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Lauren Young
Membro desde: 03/26/14
322 Reputação
Autoria de 3 guias
Equipe
Clemson, Team 6-6, Benson Spring 2014 Membro de Clemson, Team 6-6, Benson Spring 2014
CLEM-BENSON-S14S6G6
4 Membros
Autoria de 18 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 52
Ao todo: 863
