Ir para o conteúdo principal
Siemens A56 Keyboard Replacement
  1. Siemens A56 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Press down on the grooved area firmly in the direction of arrow #1.
    • While maintaining the downwards pressure, push the back cover in the direction of arrow #2 until the back cover slides off.
    • Photos taken from: http://theinformr.com/uploads/manuals/si...
    Pergunte ao FixBot
    Comentar
  2. Siemens A56 Keyboard Replacement: passo 2, imagem 1 %32
    • Turn off the phone before removing the battery to avoid damage.
    • Press the latch on the battery in the direction of arrow #3.
    • Lift battery at the cutout on the side of the phone, then tilt upwards and remove.
    • It may be necessary to use the tip of a fingernail or a plastic lifting tool to remove the battery.
    Pergunte ao FixBot
    Comentar
  3. Siemens A56 Keyboard Replacement, Front Plate: passo 3, imagem 1 %32 Siemens A56 Keyboard Replacement, Front Plate: passo 3, imagem 2 %32 Siemens A56 Keyboard Replacement, Front Plate: passo 3, imagem 3 %32
    • Firmly grasp the white casing of the phone with one hand and the blue cover with the other hand as seen in the first picture.
    • Pull up on the two plastic clips at the top of the phone.
    • While the clips are pulled up, pull the blue cover away from the white casing to remove it.
    Pergunte ao FixBot
    Comentar
  4. Siemens A56 Keyboard Replacement, Keyboard: passo 4, imagem 1 %32 Siemens A56 Keyboard Replacement, Keyboard: passo 4, imagem 2 %32 Siemens A56 Keyboard Replacement, Keyboard: passo 4, imagem 3 %32
    • The keyboard can be easily removed by hand.
    • Once the old keyboard has been removed, it is possible to replace it with a new keyboard.
    Pergunte ao FixBot
    Comentar
Conclusão
Andrew Corriveau
Membro desde: 03/26/14
97 Reputação
Autoria de 1 guia
Equipe
Clemson, Team 6-6, Benson Spring 2014 Membro de Clemson, Team 6-6, Benson Spring 2014
CLEM-BENSON-S14S6G6
4 Membros
Autoria de 18 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 45
Ao todo: 590
