Ir para o conteúdo principal
Siemens A56 Battery Replacement
O que você precisa
  1. Siemens A56 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Press down on the grooved area firmly in the direction of arrow #1.
    • While maintaining the downwards pressure, push the back cover in the direction of arrow #2 until the back cover slides off.
    • Photos taken from: http://theinformr.com/uploads/manuals/si...
  2. Siemens A56 Battery Replacement: passo 2, imagem 1 %32
    • Turn off the phone before removing the battery to avoid damage.
    • Press the latch on the battery in the direction of arrow #3.
    • Lift battery at the cutout on the side of the phone, then tilt upwards and remove.
    • It may be necessary to use the tip of a fingernail or a plastic lifting tool to remove the battery.
Conclusão
Alex Garrett
Membro desde: 03/26/14
108 Reputação
Autoria de 1 guia
Equipe
Clemson, Team 6-6, Benson Spring 2014 Membro de Clemson, Team 6-6, Benson Spring 2014
CLEM-BENSON-S14S6G6
Membros da 4
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 13
Duração total: 316
