Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Sidekick II Outer Casing Replacement
O que você precisa
  1. Sidekick II Outer Casing Replacement, Outer Casing: passo 1, imagem 1 %32
    • Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
    • Gently pry open button and remove button.
    • Do this for each of the 3 buttons remaining.
  2. Sidekick II Outer Casing Replacement: passo 2, imagem 1 %32 Sidekick II Outer Casing Replacement: passo 2, imagem 2 %32
    • The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off.
  3. Sidekick II Outer Casing Replacement: passo 3, imagem 1 %32
    • Use the T6 Torx Screwdriver to remove the 4 screws that are underneath the 4 buttons you removed in step one.
  4. Sidekick II Outer Casing Replacement: passo 4, imagem 1 %32
    • Flip the screen up halfway (90 degrees), to reveal the 2 screws above the right side of the keyboard.
    • Use the Torx 6 screwdriver to remove these 2 screws.
    • Be careful in handling the phone after removing the screws, because the two main bodies of the phone are no longer attached.
  5. Sidekick II Outer Casing Replacement: passo 5, imagem 1 %32
    • After removing the 6 screws and both bumpers, the phone will be easy to separate into the two main bodies.
    • You can use your hands to simply pull apart the top casing from the bottom casing.
Linha de Chegada
michael albaum
Membro desde: 01/20/10
87 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 3-19, Maness Winter 2010 Membro de Cal Poly, Team 3-19, Maness Winter 2010
CPSU-MANESS-W10S3G19
Membros da 4
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 18
Duração total: 2,399
