Introdução
The XLR connector is the point where the XLR cable is inserted into the microphone. The XLR cable carries the signal to the sound mixer and speakers.
O que você precisa
Using a small flat head screwdriver, gently turn the retaining screw at the bottom of the microphone counterclockwise until it stops or provides resistance.
After installing the connector back into the microphone, it should be ready to connect to any XLR cable.
4 outras pessoas executaram este guia.
7 comentários
Thanks for this. I had a connector where the screw had come loose and the whole assembly had released and become jammed halfway into the housing, with the 3 prongs halfway exposed. I couldn’t quite figure out what was going on with it because it was really bound in there tightly, but your guide helped me sort out what was wrong, remove the connector assembly, and get it reseated properly in the mic housing. Thanks again!
Hi, I am trying to troubleshoot a very old 58, and the xlr connector screw wont stop turning (anti clockwise) and connector still wont come out. What should I try?
The retaining screw at the bottom of the microphone is gone and I am searching for a replacement. What is the specific name of the screw? Thank you!
It’s a grub screw. Just get hold of a Switchcraft Male XLR plug, either new or from an old mic cable, and and remove the screw. Remember the thread is reversed from a normal screw, which is why this is the best way to get a replacement.
