Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
The XLR Connector is the part of the microphone that plugs into the cable which carries the sound to the sound mixer and speakers.
O que você precisa
Using a small flat head screwdriver, gently turn the retaining screw at the bottom of the microphone counterclockwise until it stops or provides resistance.
After soldering the wires to the XLR connector and reassembling your microphone, your microphone should be ready to plug in to the XLR cable and function properly.
4 outras pessoas executaram este guia.
9 comentários
I'm not familiar with the "pin 2 hot method." We took a working mic apart and reassembled it the way we found it, so I'm pretty that is the correct soldering configuration.
Świetna strona. Brawo.
