Ir para o conteúdo principal
Shure SM58 XLR Connector Replacement
O que você precisa
  1. Shure SM58 XLR Connector Replacement, Connector: passo 1, imagem 1 %32 Shure SM58 XLR Connector Replacement, Connector: passo 1, imagem 2 %32 Shure SM58 XLR Connector Replacement, Connector: passo 1, imagem 3 %32
    • While holding the microphone connector in one hand, and the XLR cable in the other hand, slowly pull them apart.
    • Make sure you are not holding the microphone connector by the wires.
    • Check to make sure all of the internal wires are connected. If you see a disconnected wire, take a look at the connector soldering guide.
  2. Shure SM58 XLR Connector Replacement: passo 2, imagem 1 %32 Shure SM58 XLR Connector Replacement: passo 2, imagem 2 %32
    • Hold the microphone connector in one hand and the microphone base in the other.
    • Line up the screw in the connector with the hole in the middle of the microphone.
    • Also, align the ridge on the microphone connector (located near the top of the connector) with the slot in the base of the microphone.
  3. Shure SM58 XLR Connector Replacement: passo 3, imagem 1 %32 Shure SM58 XLR Connector Replacement: passo 3, imagem 2 %32
    • With those parts aligned, push the connector back into the microphone until the screw lines up with hole in the side of the microphone.
    • Do not push the microphone past this point or the connector may become stuck.
  4. Shure SM58 XLR Connector Replacement: passo 4, imagem 1 %32
    • Using a small flat head screw driver, turn the screw in the side of the microphone clockwise until it is tight.
Conclusão
Following these steps should reinstall the XLR connector back into the microphone.
nat coll
Membro desde: 09/27/12
642 Reputação
Autoria de 14 guias
Equipe
Cal Poly, Team 7-53, Forte Fall 2012 Membro de Cal Poly, Team 7-53, Forte Fall 2012
CPSU-FORTE-F12S7G53
Membros da 5
Autoria de 20 guias
2 comentários
simple clear and precise. Small problem fixed in no time, thank you very much!
Kimmo Pekari - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 70
Duração total: 17,225
