Ir para o conteúdo principal
Shure SM58 Grille Replacement
  1. Shure SM58 Grille Replacement, Grille: passo 1, imagem 1 %32
    • Hold the microphone just below the grille with one hand while using your other hand to rotate the grille clockwise to remove.
  2. Shure SM58 Grille Replacement: passo 2, imagem 1 %32 Shure SM58 Grille Replacement: passo 2, imagem 2 %32
    • Completely unscrew the grille and slide it off of the top of the microphone. The unprotected microphone is delicate, so place it somewhere safe while you follow the next steps.
Conclusão
Follow the steps in reverse to install the new grille on the microphone.
5 outras pessoas executaram este guia.
nat coll
Membro desde: 09/27/12
642 Reputação
Autoria de 14 guias
Equipe
Cal Poly, Team 7-53, Forte Fall 2012 Membro de Cal Poly, Team 7-53, Forte Fall 2012
CPSU-FORTE-F12S7G53
Membros da 5
Autoria de 20 guias
2 comentários
Can you change the grilles of sm58 and sm86?
Jack - Responder
Hello, I have two SM58 (wired), No matter how I tried to remove the grill from one of them, It just would not budge. With the other one, The grill comes off, but the base refuses to unscrew. Can you tell me how to solve this issue? Thanks in advance.
junia joseph - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 35
Duração total: 10,022
