Ir para o conteúdo principal
Shure SM58 Capsule Installation Replacement
O que você precisa
  1. Shure SM58 Capsule Installation Replacement, Collar: passo 1, imagem 1 %32 Shure SM58 Capsule Installation Replacement, Collar: passo 1, imagem 2 %32 Shure SM58 Capsule Installation Replacement, Collar: passo 1, imagem 3 %32
    • Grab the microphone base with one hand. With the other hand, grab just below the grille (the collar). Twist the collar clockwise to loosen it.
    • Be careful to not pull on the collar or you may rip the wires from the faceplate.
  2. Shure SM58 Capsule Installation Replacement, Faceplate: passo 2, imagem 1 %32
    • Remove the yellow and green wires from the face plate.
    • Note which side the yellow and green wires connect to.
    Why should I replace the plate?
    Gerrit - Responder
    This guide was done as part of the capsule replacement—I don’t think there is any reason to solely replace the plate unless there was corrosion on it.
    Daniel Berger - Responder
  3. Shure SM58 Capsule Installation Replacement: passo 3, imagem 1 %32 Shure SM58 Capsule Installation Replacement: passo 3, imagem 2 %32
    • Never open the microphone capsule. Attempting to open the capsule will likely result in permanent damage and make the microphone unusable.
    • Using an adjustable crescent wrench, remove the nut and washer from the face plate by twisting the nut counterclockwise.
  4. Shure SM58 Capsule Installation Replacement: passo 4, imagem 1 %32 Shure SM58 Capsule Installation Replacement: passo 4, imagem 2 %32
    • Slide the face plate over the connector.
  5. Shure SM58 Capsule Installation Replacement, Capsule Installation: passo 5, imagem 1 %32 Shure SM58 Capsule Installation Replacement, Capsule Installation: passo 5, imagem 2 %32
    • Using an adjustable wrench, remove the nut and the washer behind the face plate by twisting the nut counterclockwise.
  6. Shure SM58 Capsule Installation Replacement: passo 6, imagem 1 %32
    • Hold the body of the microphone, right below the grille, in one hand. Using your other hand, rotate the grille clockwise.
    Step 6 is incorrect. The grill screws off counter clockwise.
    Bill Kahler - Responder
  7. Shure SM58 Capsule Installation Replacement: passo 7, imagem 1 %32
    • Slide the grille off the top of the microphone once it is all the way loosened.
  8. Shure SM58 Capsule Installation Replacement: passo 8, imagem 1 %32 Shure SM58 Capsule Installation Replacement: passo 8, imagem 2 %32 Shure SM58 Capsule Installation Replacement: passo 8, imagem 3 %32
    • Hold the black plastic piece under the grille in one hand. In the other hand, hold the microphone collar.
    • Slowly, pull upward while twisting the black plastic piece clockwise.
    • Be careful not to scratch the copper microphone capsule. Another face plate may fall out when removing capsule.
    • Never open the microphone capsule. Attempting to repair the capsule will result in permanent damage.
    Can you replace the yellow tape/cable if broken? (seen in last pic)
    karl_ivers - Responder
    Honestly, I’m not sure. If I was in your position, I would assume a similarly sized piece of electrical tape should be fine, but if you’re not sure you may want to contact a repairman.
Conclusão
Once installed, reassemble the microphone following the steps in reverse.
7 outras pessoas executaram este guia.
nat coll
Membro desde: 09/27/12
642 Reputação
Autoria de 14 guias
Equipe
Cal Poly, Team 7-53, Forte Fall 2012 Membro de Cal Poly, Team 7-53, Forte Fall 2012
CPSU-FORTE-F12S7G53
Membros da 5
Autoria de 20 guias
5 comentários
Thanks for that,
Can i just replace the capsule as seen in the last picture?
Has it to be resoldered? Where do those very fine copper wires go?
Eanoid - Responder
It's been a few years since I made the guide and no longer have any microphones nearby to examen, but if I remember correctly, there is no soldering between the capsule and the housing. I believe the housing is soldered to the rest of the body with the silver leads at the bottom left of the picture.
Daniel Berger -
Somehow the grill got really stuck and I want to replace it. It it screwed or is it as you've said - slidable?
arnold - Responder
You can unscrew just the grill.
Burke McQuinn - Responder
Hi, a bit unrelated but I accidentally twisted the black plastic piece slightly while everything was still intact. I turned it back though, did I damage the SM58 in any way?
Emje De - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 43
Últimos 30 dias: 231
Duração total: 39,222
