Ir para o conteúdo principal
Shure SM58 Capsule Installation Replacement
O que você precisa
  1. Shure SM58 Capsule Installation Replacement, Collar: passo 1, imagem 1 %32 Shure SM58 Capsule Installation Replacement, Collar: passo 1, imagem 2 %32 Shure SM58 Capsule Installation Replacement, Collar: passo 1, imagem 3 %32
    • Grab the microphone base with one hand. With the other hand, grab just below the grille (the collar). Twist the collar clockwise to loosen it.
    • Be careful to not pull on the collar or you may rip the wires from the faceplate.
    Pergunte ao FixBot
    Comentar
  2. Shure SM58 Capsule Installation Replacement, Faceplate: passo 2, imagem 1 %32
    • Remove the yellow and green wires from the face plate.
    • Note which side the yellow and green wires connect to.
    Pergunte ao FixBot
    Comentar
  3. Shure SM58 Capsule Installation Replacement: passo 3, imagem 1 %32 Shure SM58 Capsule Installation Replacement: passo 3, imagem 2 %32
    • Never open the microphone capsule. Attempting to open the capsule will likely result in permanent damage and make the microphone unusable.
    • Using an adjustable crescent wrench, remove the nut and washer from the face plate by twisting the nut counterclockwise.
    Pergunte ao FixBot
    Comentar
  4. Shure SM58 Capsule Installation Replacement: passo 4, imagem 1 %32 Shure SM58 Capsule Installation Replacement: passo 4, imagem 2 %32
    • Slide the face plate over the connector.
    Pergunte ao FixBot
    Comentar
  5. Shure SM58 Capsule Installation Replacement, Capsule Installation: passo 5, imagem 1 %32 Shure SM58 Capsule Installation Replacement, Capsule Installation: passo 5, imagem 2 %32
    • Using an adjustable wrench, remove the nut and the washer behind the face plate by twisting the nut counterclockwise.
    Pergunte ao FixBot
    Comentar
  6. Shure SM58 Capsule Installation Replacement: passo 6, imagem 1 %32
    • Hold the body of the microphone, right below the grille, in one hand. Using your other hand, rotate the grille clockwise.
    Pergunte ao FixBot
    Comentar
  7. Shure SM58 Capsule Installation Replacement: passo 7, imagem 1 %32
    • Slide the grille off the top of the microphone once it is all the way loosened.
    Pergunte ao FixBot
    Comentar
  8. Shure SM58 Capsule Installation Replacement: passo 8, imagem 1 %32 Shure SM58 Capsule Installation Replacement: passo 8, imagem 2 %32 Shure SM58 Capsule Installation Replacement: passo 8, imagem 3 %32
    • Hold the black plastic piece under the grille in one hand. In the other hand, hold the microphone collar.
    • Slowly, pull upward while twisting the black plastic piece clockwise.
    • Be careful not to scratch the copper microphone capsule. Another face plate may fall out when removing capsule.
    • Never open the microphone capsule. Attempting to repair the capsule will result in permanent damage.
    Pergunte ao FixBot
    Comentar
Conclusão
Once installed, reassemble the microphone following the steps in reverse.
9 outras pessoas executaram este guia.
nat coll
Membro desde: 09/27/12
859 Reputação
Autoria de 14 guias
Equipe
Cal Poly, Team 7-53, Forte Fall 2012 Membro de Cal Poly, Team 7-53, Forte Fall 2012
CPSU-FORTE-F12S7G53
5 Membros
Autoria de 33 guias
5Comentários do guia
Thanks for that,
Can i just replace the capsule as seen in the last picture?
Has it to be resoldered? Where do those very fine copper wires go?
Eanoid - Responder Compartilhar
It's been a few years since I made the guide and no longer have any microphones nearby to examen, but if I remember correctly, there is no soldering between the capsule and the housing. I believe the housing is soldered to the rest of the body with the silver leads at the bottom left of the picture.
Daniel Berger - Responder Compartilhar
Somehow the grill got really stuck and I want to replace it. It it screwed or is it as you've said - slidable?
arnold - Responder Compartilhar
You can unscrew just the grill.
Burke McQuinn - Responder Compartilhar
Hi, a bit unrelated but I accidentally twisted the black plastic piece slightly while everything was still intact. I turned it back though, did I damage the SM58 in any way?
Emje De - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 18
Últimos 7 dias: 65
Últimos 30 dias: 274
Ao todo: 44,872
