Ir para o conteúdo principal
ShowerDoorDirect Shower Speaker Battery Replacement
O que você precisa
  1. ShowerDoorDirect Shower Speaker Battery Replacement, Battery: passo 1, imagem 1 %32 ShowerDoorDirect Shower Speaker Battery Replacement, Battery: passo 1, imagem 2 %32
    • Remove the suction pad by pulling the suction out of the slot that it is in.
  2. ShowerDoorDirect Shower Speaker Battery Replacement: passo 2, imagem 1 %32
    • Remove the four 9.09mm Philips #1 screws that hold the 2 pieces of the cover together.
    • Pull apart the two halves.
  3. ShowerDoorDirect Shower Speaker Battery Replacement: passo 3, imagem 1 %32
    • Hold the base and pull up on the battery.
  4. ShowerDoorDirect Shower Speaker Battery Replacement: passo 4, imagem 1 %32 ShowerDoorDirect Shower Speaker Battery Replacement: passo 4, imagem 2 %32 ShowerDoorDirect Shower Speaker Battery Replacement: passo 4, imagem 3 %32
    • Remove the four 5mm Phillips #1 screws from the motherboard.
    • Desolder the two wires connecting the battery tp the motherboard.
Conclusão
Matthew Dunkle
Membro desde: 05/21/18
203 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S1-G1, Harley Spring 2018 Membro de IUPUI, Team S1-G1, Harley Spring 2018
IUPUI-HARLEY-S18S1G1
Membros da 7
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 543
