Introdução
Follow this guide to remove and replace the power switch on the MC150A Shop-Vac.
O que você precisa
Unlatch the two side clips securing the power unit assembly to the tank.
Remove the power unit assembly from the tank assembly.
Use a 3.5 mm hex key to remove the three screws securing the top cover.
Remove the top cover.
Pull out and disconnect the four spade connectors from the switch module.
6 outras pessoas executaram este guia.
