Ir para o conteúdo principal
Shoe Buckle Replacement
O que você precisa
  1. Shoe Buckle Replacement, Shoe Buckle: passo 1, imagem 1 %32 Shoe Buckle Replacement, Shoe Buckle: passo 1, imagem 2 %32 Shoe Buckle Replacement, Shoe Buckle: passo 1, imagem 3 %32
    • Begin by opening the buckle on the shoe you want to change.
  2. Shoe Buckle Replacement: passo 2, imagem 1 %32 Shoe Buckle Replacement: passo 2, imagem 2 %32 Shoe Buckle Replacement: passo 2, imagem 3 %32
    • Examine the back of the strap to locate the seam.
    • Gently unthread the stitches from the back, and work your way to the front with the seam ripper.
  3. Shoe Buckle Replacement: passo 3, imagem 1 %32 Shoe Buckle Replacement: passo 3, imagem 2 %32 Shoe Buckle Replacement: passo 3, imagem 3 %32
    • Now, open up the strap attached to the old buckle and slide it off.
  4. Shoe Buckle Replacement: passo 4, imagem 1 %32 Shoe Buckle Replacement: passo 4, imagem 2 %32 Shoe Buckle Replacement: passo 4, imagem 3 %32
    • Put your new buckle back onto the strap you just unstitched.
  5. Shoe Buckle Replacement: passo 5, imagem 1 %32 Shoe Buckle Replacement: passo 5, imagem 2 %32 Shoe Buckle Replacement: passo 5, imagem 3 %32
    • Let's begin with the threading process.
    • To begin, thread the needle by passing the thread through its eye.
    • Then, align the unstitched strap with the old stitching onto the shoe, as this will act as your guide.
  6. Shoe Buckle Replacement: passo 6, imagem 1 %32 Shoe Buckle Replacement: passo 6, imagem 2 %32 Shoe Buckle Replacement: passo 6, imagem 3 %32
    • Once it's aligned, use the previous stitching holes as a guide to begin stitching.
    • After completing the process, proceed to tie the thread.
  7. Shoe Buckle Replacement: passo 7, imagem 1 %32 Shoe Buckle Replacement: passo 7, imagem 2 %32
    • Finally, use the seam ripper to cut off the remaining thread.
Conclusão
Uma outra pessoa concluiu este guia.
Alyssa Tu
Membro desde: 10/29/23
145 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 53
Ao todo: 1,063
